Forge TIP
Right need some pics of a fitted tip on a 1.8t FR or Cupra. I have mine fitted and have done for some time but the other day i noticed some sort of black coolant pipe pushing against it need the bottom before it hits the turbo.
Any pics of anyone else with it fitted looking down towards the turbo would be great. Just want to make sure its fitted right.
cheers
the bolt is threaded into the engine the bolt gets put back where its come from but not with the hard pipe attached,so when the bolt is put back in and tightened its holding the hard pipe off the tip.
your see what i mean when you come to do it or you should do.
