Forge TIP Mk4 Cupra
Jan 14, 2005
1,308
Cannock/Wolvo
I have one on mine and have had no problems at all. my car was used for the development of the pipe and iv had it on the car 2-3months now with no probs. have you spoke to Forge???
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
The forge TIP's are a rough fit on the Cupra 20vT not worth gettin until they sort it out they rub on the engine crapy design [:@]
ive just ordered 1 in red for mine it better fit or im not going to be happy what exactly does it rub on?? the cupra wont be much diffrent to the fr where the tip fits. it should be fine!
gazjones
no problems on forges side fits perfect i just needed to slightly bend the corner of a heat shield and wrap a gear linkage in smooth tape as it had worn away part of the metal original tip!!! sure you havent to it twisted on the turbo meaning its putting everything out of line at the top!
gazjones
bbu is the same layout and is pysically the same as the bjx fr engine
Ric 2001
Need an ID-ten-T form
Which one should i go for then as I have BBu engine code and its not listed?
Had a quick look last night will post pics later (to cold and dark). The only thing rubbing against my TIP is a small black pipe with is made out of rubber.
Just need a 70-90 Jubilee clip to replace them cable ties
Double check that your not looking at the Mk3 TIP as they are the same price. (Bigar have you bought the mk3 tip!?)
You should be look at http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=1304SILH&product=FMINDIBFR4
rashcupra
Oct 15, 2006
6,517
crawley
looks great! my engine cover batery cover and liquid caps are all getting sprayed tomorrow or day after so along with both the pipes its going to look mint :D
Cupra_Jay
Orange Wheels FTW!!
Oct 25, 2006
927
Pub!!
pipe looks good
rash - what colour you having your stuff sprayed? will be interesting to see what they look like
