Forge - Silicone High Temp Nomex Turbo Hose for SEAT Ibiza MK3 1.8T
ForgeMotorsport
Link here
to the Forge section just making sure you guys dont miss it as I know there were quite a few waiting on it
http://www.seatcupra.net/forums/showthread.php?p=1089841#post1089841
pickie
222
?? where does this go ?? i have a forge TIP, so what is the perpose of this little peice of tube ?? also if you have a standard tip ???
Dec 31, 2005
1,856
London
If its the 54-48 reducer it comes off the top of your turbo to connect to your charge pipe, especially good if you put a k03s on, my standard reducer kept popping off until i got this one on there.
ForgeMotorsport
This hose fits directly to the turbo. It is made from high temperature resistant Silicone compound and nomex reinforced to withstand the high pressures that may be experienced on tuned engines. This is the perfect replacement for the OEM hose which can fail when engine performance has been increased.
Ibiza Cupra
Sorry for being stupid but wot difference would this have???? All the samco hoses; are they for looks???? Or just essential for seriously modded cars and conversions???? Such as wot difference is a TIP gonna have on my car???
beezaturbo
341
Staffordshire
they will withstand a lot higher pressures. the idea behind a samco tip is that the original is very restrictive and also can collapse under serious pressure. the samco one is less restrictive and will give a few around 6bhp gains.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
can we just get something straight....this isnt a Turbo Intake Pipe (TIP)
this is a reinforced hose that fits onto the turbo - intercooler pipe over the engine!
J1MMY
the man with the van
Jun 30, 2005
65
brizzle
Is this one particularly more heat resistant than using a "normal" silicon hose or will it be ok? As i've only just been up to you guys (mon) and bought a 90 deg reducer so i can fit custom boost piping to my K03S.......
flashbsd
ive got a £5 standard silicon hos eon mine, 54-48 reducer, if it gets damaged by heat in the next year ill buy everybody a pint. Ive run at the pod etc and its still fine.
Jonzy
2 mikalor clamps and a robbed scamco reducer is holding up well on mine :)
flashbsd
i stripped two mikalor clamps i did them up that tight! back to some rally clips, which i cannot fault, they allow the hose to expand inside without loosing tension etc.
acidstrato
Dec 9, 2004
5,942
good for the both of you...dont forget that this actually came about because it was requested by people! Forge didnt develop it in the knowledge that people will buy it even if they dont need it...people had problems...and this is the solution
