Forge 007p leak test
tstrahonja
541
My cupra doesnt boost over 0.8,0.9 bar. It used to spike to 1.4 and then slowly drop..
I tried boost leak test with a biciyle pump pressurising the system and DV starts to leak back into intake when i pump in 0.6, 0.7 bar.
Would that be my problem?
Or is that normal?
Nov 2, 2004
9,335
South Wales
Push the piston up inside the valve.
Cover the nipple with your finger.
Let go of the piston.
If theres suction on your finger which holds you have no leak. If there is no suction on your finger you have a leak and need to contact Forge for a service kit.
tstrahonja
541
Tried that, seems that there is no leak..how come it is leaking boost when i test it using bicycle pump....
Jul 4, 2010
2,170
Cambs
you might aswell get a service kit from forge at the same time just to be safe only about £12.. + the spring will be the same again.. Enter discount code of "SC10" and get 10% off :)
tstrahonja
541
forge isnt mine, just borrowed it from a frend to try it out.
be4 spending money on another DV i just want to make sure that mine is broken.
i am still unsure if mine is broken, and should DV leak like on the picutre.
