folding Mirrors
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
its switch that u use adujst the mirrors, to fold them, just turn the nob clockwise. (note if dont have it - dont force it- it may brake)
cupralite
173
Warrington
Nope - definitely NOT folding and no broken switch ;)
Does it turn until the mark is pointing downwards - there should be a symbol at the bottom??
You will need to turn your ignition on for it to work. It does work when you have been driving and have switched your engine off - up to the point where you remove your key.
Edit: Do you mean they are not folding when they should be or that they are definitely not folding mirrors?! Feel free to ignore the above!
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
There's no symbol at the bottom of mine and the dial definitely won't turn past the drivers side mirror select point. I am pretty sure they're just not folding ones although they are heated.
That's with ignition on or off :)
cupralite
173
Warrington
Yeah they are not folding mirrors. Phew, at least that's sorted!
:funk:
lc_allan
Northern Monkey
Sep 15, 2006
3,389
You probably don't have them then :(, there would be a mark at the 6 '0 Clock position to turn to.
Big_daddy
Oct 20, 2006
3,930
Brummy
Yeh, but i herd that you cant fold electric mirrors manualy, thinks it states that in the manual.
has any tried folding them? did they mess up or still work?
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Yeah I've done it as I had no choice the motor needed reseting/the unit was replaced under warranty. The mechanics at seat said you can do it occasionally if you really have to. As long as the button is in the right position relevant to where you want to move them to.
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
YAY - found out on my way home last night - my mirrors are electric folding AND heated :)
You need to put on your rear window heater for them to come on - cheers guys
Big_daddy
Oct 20, 2006
3,930
Brummy
Its not sure, its 50/50 thing . some leons have them and some dont. its a factory fitted thing. Most cupra dont have them.
Big_daddy
Oct 20, 2006
3,930
Brummy
its the same nob. instead turning it clock wise 6clock to fold the mirrors in.
To adjusat the left mirrors, turn the nob to 10 clokc and nobn becomes into a joystick that you could move mirror up, dwn, left right.
The adujst right turn the nob to 2 clock. and adujst the nob to move the mirror
