fmic difference
sooty22
sooty22
Dec 28, 2006
726
nera richmond north yorks
hi im in the process of buying a forge fmic kit its to fit a pd130 been re-mapped. what sort of increase am i looking at? anyone know of before/after results etc..... also how do you find out your inlet temp? cheers chris:)
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
you'll need Vagcom software and a laptop to log your inlet temps.
My temps dropped from 90deg+ to less than 40deg!
Well worth the money, car felt like it could pull for a tad longer without getting out of breath...
You will notice it so much more in the summer due to heat soak.
sooty22
sooty22
Dec 28, 2006
726
yeah nice one! i ran a 15.1 at santa pod dragway right in the red hot sun last summer so this will deffo give an improovement on 1/4mile times? what you mean pull better at top end speed?
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
i managed a 14.8 with the standard smic on...!
the car seems to pull the same throught 3rd 4th and into 5th wheras before it used to get a bit wheezy high up in the rev range when accelerating.
Mine actually went into limp mode when the intake temps hit 93 degress!
timbotdi
213
As a general rule, a FMIC doesn't add any BHP, simply lowers the inlet temperatures - on a quarter mile run you may see some increase as the turbo can breathe better, but it will be nominal.
T
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
it made it feel a tad quicker...
unfortunately ive sold the car now.
it got RR'd at 162bhp atw and 302lb/ft, about 185+bhp at the fly...
Fez boy
560
Watford
I had the Forge fitted but when I added the Cupra bumpers to the car I changed the FMIC for the SS unit.
Not sure there was a real difference but the temps were a couple of degs lower(even though it was not the same weather when I tested the forge unit)
The turbo spooled up a few hundred rev quicker but it would hold the boost more higher up the range.
It's a must for mapped cars and the summer weather IMO ;)
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
the panel filter and cupra intake is also highly recommended.
then rear spacers
312mm TT brakes
Coilovers
Big turbo!!!
JBS Sales
I did a few logs on my Ibiza with a C-C remap and standard SMIC temps went to 70 degrees and a friend of mine had Cupra bumpers on his 130PD sport with SMIC temps went to 90!!!
Fitted the Forge FMIC on both cars (very good product I might add) and temps never went over 40!
Recommend to all - get a Custom-Code P2 map too and the car will pull all the way to 5K - mine sure does :D
The PD160 intake is about a twice as wide as 130 - it’s the pipe between the air box and front panel.
Mike
P.S we are offering 10% and FOC delivery on Green filters :)
sooty22
sooty22
Dec 28, 2006
726
yeah i bought a pipercross pannel filter.... awsome gti are doing an offer on them at the mo.... you lot are tempting me on the fmic tho!so as i have now got the pannel filter and will get the fmic will the next ster be a custom code re-map stage 2?
D-Power
110
Newmarket
I'm looking to get a remap in the next month or so, are inlet temps of say 70 potentially damaging or just not condusive to performance?
If i do fit a FMIC will i need cupra bumpers and how much will it cost including fitting (PM me if you like!)
JBS Sales
Intake temps of 70 will be fine, if it was to go higher the ECU has safety parameters and will reduce boost to lower temps
You do not need a Cupra bumper to have the FMIC :)
Forge FMIC comes to £715.00 delivered or £908.87 fitted
Mike
