Hey Chaps.
The car seems to boost fine usually, and this is NOT an intermittent problem. From about 3 to 3.5krpm the car accelerates, but doesn't seem to boost as much or as with as much force before or after this range. It's not a massive drop, but it is noticable. As when you floor it, pick up from 2.5k is awesome, slows down at 3k, them picks back up around 3.5k.
Is this a MAF problem?
As another question (as I don't have another LCR to compare with) When you change up a gear (during acceleration) I change up, then fire back on the throttle. It takes a second or 2 and then you feel the acceleration come back on. I am assuming this is just turbo lag after changing gear, and not anything else. But I thought I may as well ask
Thanks!
Thanks!
