I fitted my turbo back exhaust today, and to say im happy with the results would be an understatement, it fits perfectly and sounds lovely when you want it to (when your accelerating and not just cruising).
I would like to give all the peeps in the Blueflame GB a bit of advice though...... please please please do not do this yourself on your driveway at home... if you have a lift then you might have an easier time but after a call to blueflame i found out it takes them 3 hours to get the OEM downpipe off..
you have to remove all shields from the tunnel to stand any sort of chance of getting it off... every nut on my cat was severly corroded and needed to be cut off. i had to use a oxyceteline torch to heat up the boss with the post cat lamba in to get that out. the 3rd section of the exhaust that goes over the rear axle was an absolute bitch to get on... i had to remove the lower bolts on the rear suspension and fiddle around with shields to get it anywhere near to going over...... i started at 10.30 this morn and finished at 9.30..
i have fitted loads of exhausts, rebuilt engines, put different engines in all sorts of cars but this job is by far the worst i have ever undertaken..
please take my advice and spend the extra to get it fitted... i would if i had another chance.
