I'm going to attempt to put the TIP I bought at inters on at the weekend along with the Forge DV and charge pipe.
Is there anything specific I should look out for while doing it? Any tips? Things I can also remove to make things easier for myself? Any specific tools I'll need?
Also as most of the vacuum hoses (not directly attached to the TIP) that will need to be removed in the process are attached with clips that'll have to be broken off what size jubilees should I go for to replace them?
Any advice / instruction would be great!
