Fitting Fmic Without Another Remap
jason-jm
414
Im currently running a standard turbo
cat back exhaust
recirc DV
AMD Stage 1 remap
and a filter tomorrow..
If I fitted a fmic how would it run..
TurboCupra
190
The ECU will 'trim' itself with the built in temp correction whatever map you have.
Therefore the lower the inlet temp, the more power being produced. As the ECU allows more ignition advance, and more petrol? etc due to the air being more cold/dense.
Or at least that my understanding of it?
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Take your car out at night in the cold (this time of year is perfect), and it'll feel like its pulling harder than it does in the middle of summer in the day. Thats the same sort of effect you'll get from the intercooler.
jason-jm
414
What will I need to get it to fit?
much work? and will it sit behind my bumper?
jason-jm
414
SO DOES THAT MEAN IN THIS COLD WEATHER IT WILL PULL EVEN HARDER :eek::confused::drool:
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
SO DOES THAT MEAN IN THIS COLD WEATHER IT WILL PULL EVEN HARDER :eek::confused::drool:[/QUOTE]
i Think it should meself but im no expert, lol. ive just ordered meself a forge fmic-carnt wait to get it, after fitting it i hope it pulls better than i do on a night out! :redface:
jason-jm
414
Yeah It shouldn't take much matey :p
jokes
£700ish is alot of money isnt it.. is that how much you paid
ian_cupra
noticed mine was peaking higher boost last nite, its awesome, the cold weather helps so much :)
Beaker™
Nov 21, 2005
1,900
C:\UK\Glos
Yeah, the colder the weather the harder it pulls. If you need time to save up then nows perfect as the weathers cooling off for the winter anyway so you wont 'need' an intercooler as much over the winter. Why not save up over the winter and get it fitted ready for next spring/summer.
jason-jm
414
Jabba quoted me £690 for standard thickness or £700 for thicker one which means removing aircon...(NO THANK YOU)
Would jabba be better than forge?
hmm laguna might not be a perfect fit :(
