redgt
118
do i just take the little cap off the round connector thing near the washer bottle and connect the boost pipe to that?
the green nipple off the brake servo pipe - you can do or t-piece inro the vac pipe from the top of the dump valve or t-piece into the fpr line
I cut into the vac pipe coming from the fuel pressure regulator, when I sold my gauges i couldnt remove the t-peice as it was extremely tight so I trimmed the end of the pipe and taped it closed for the time being until I begin work on minting up the engine bay with more samco's, vac pipes, polished inlet and rocker cover etc
