i bought a strut brace for my ibiza about 2 months ago, and its still sitting in the garage! when i seen it needed drilling, i thought it would be best left to the pros!
nah its easy, it's true wat F2 stu says about the coach bolts.
What coach bolts?
Its an easy job, all you do is place the brace on, use a drill bit that fits the holes nicely, and spot where the hols got then use a smaller drill bit to suit the self tapers supplied.
You could use M6 nut & bolts instead wigh would be a better fixing but is a right PITA do to with the suspension struts in situe.
here's mine (poor quality pics)
Note: in first pic, i had to extend the boonet switch cable, and rotate the metal bit 180 degrees to let the strut fit better
