Fitted My Defi Gauges
Ric 2001
Need an ID-ten-T form
Got my Boost pressure and oil pressure Defi BF gauges from awesomegti.com (thanks Andy). Also they managed to gey a Nomad Racing A piller in black with 2 pods.
Will update the pictures when it gets dark.
Off
Where Controller Box is Housed.
Got some reading last night:
The first thing I notice is that the gauge gives a negative boost on tick over.
Peak of 0.9bar approx 13psi
Holds at 0.6bar approx 8psi
Ric 2001
Bunnin said:
Looks pretty sweet !
The defi box that takes all ur readings does it ?
Yeah, it can give you the peak of each meter, and a last 3 minute play back. You can set different warning points on each meter as well. The opening and ending ceremony is cool too.
Fez boy said:
Looks very nice ;)
Whats the view like with the A pillar pod in?
Defi's are the nuts :D
That picture is not the driving view, and the pillar pod doesn't impair your view of the road.
Ric 2001
Yeah thought it would be difficult, but after some thought, just getting to the oil pressure sensor was a pain in the #@*.
No tubing of any sort goes anywhere near the cabin. It all within the engine bay, the only things to pop through to the cabin side is 2 electrical wires which connect to the controller unit.
The controller unit is the brain with just one wire going to on of the gauges and then its daisy chained up from there.
Within the gauges there are chips, which decode the information from the controller unit and know which information to use for each gauge.
To get power I end up piggy backing off the ISO loom of the head unit, because the wiring supplied was a little to short to get to the headlight switch.
Wiil take some photo of the installation if you want (I'll resize them too.)
grq
Giggity
Jun 9, 2005
170
stoneyfordNI said:
i didnt tempt him to say that
my hat is tipped kind sir
Not at all, I said it of my own free will, now will you put the gun away :lol:
