Spent a few hours fitting the tank in 80 degree heat, made an L shape bracket to mount it off the battery tray next to the power steering bottle. Used the original breather hose but reversed and extended to fit to the inlet on the tank then some new 19mm hose for the outlet up to the breather filter on the TIP. Glad I managed to use the original hose without cutting, means I can take it back to standard at any time.
Few pics from my mobile, pretty pleased with it. Probably change the hose clips for newer ones and might beef up the bracket but it'll do for now. Be interesting to see how much oil is collected. Should hopefully keep the TIP and intercooler hoses oil free
