fitted a new d/valve and now its not boosting as high
jay26
197
scunthorpe
right just fitted a new forge 007p dv as the bailys one that was on it was leaking and now my boost gauge is reading about 5 psi lower it use to boost to 16 psi then drop and hold at 15 psi but now it seems to boost up to about 12-13 psi and hold ther:confused:
is this becouse it dont have to compensate for the leaking one or something like that :confused:
anyone know for sure what it is :help:
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Is it all conneted tight not leaking anywhere. What spring did u have in the bailey one.? have u fitted it the right way. I Read a thread earlier about the springs and d/v and fitting the 007p backwards and having to counter the boost with a stronger spring.
jay26
197
scunthorpe
no mate mine was lower than it should be ive serviced the balieys one and put it back and its fine again
chrisjackson
green or yellow springs for forge 007. if it has a yellow fitted it may be to stiff so may be worth dropping to the softer green 1
