You have been able to get side repeaters for years!!!! Just not advertised as for
Ibiza's!
You honestly can't think that the MK4 (6L)
Ibiza would have its own set of side repeaters which aren't shared at all across the VAG range!!!
The round Mk3 Golf ones fit fine!
Sorry, but that isn't entirely true and I'm sure someone here will hopefully back me up on this? Late Mk3 Golf and all Mk4 Golf Repeaters will fit into the wing of the car, that isn't the
problem.....what is a
problem is the bulb holder fitment. Because I've not made 15 posts yet I can't post links to pictures, etc but I will try to explain as best as I can just now and I'll post some pictures up which explain things better as soon as I can.
Late Mk3 Golf Repeaters will fit straight onto a Mk2 6K
Ibiza and will match the bulb holder fitment with no problems.
If you try to fit Late Mk3 Golf Repeaters to a 6L
Ibiza you will run into trouble with the bulb holder fitment because they are the same as a Mk4 Golf,The Mk4 Golf Fitment will fit all 6L Ibizas but only up to mid 2003 because during 2003 Seat changed their side repeaters from the VAG Golf Mk4 Bulb Holder Fitment to one of there own, the visible outside difference is that the later repeaters have an amber centre ring rather than the chrome centre ring which the pre-2003/Mk4 Golf lights had.
The 2003 on Seat Side Repeaters have a totally different bulb holder fitment to any of the VAG range, this fitment is common to all Seats from mid 2003 on so, a 6L
Ibiza, a 6J
Ibiza (2008 on) or any other Seat from mid 2003 on will not be able to have a Mk4 Golf fitment repeater unless you started to change bulb holders, etc. These repeaters which I'm selling are a direct fit, no changing of ulb holders or messing around at all, just a straight swap for the original ones.
I hope that has helped explain things a little further, I'll hold my hands up and admit I'm not a Seat expert but I did put a massive amount of effort into getting these lights into the market place and in trying to make it clear which models they will and won't fit.
Can someone who's come across the bulb holder fitment problems confirm what I'm saying above please?
