Fiat Coupe 20v Brakes???
Pingu101
28
Rite ive done a search but come up with no definate answer.
will the brembos fit from a fiat coupe??? (mk3 ibiza cupra)
i realise theyre's gonna have to be some modification
all help greatly appreciated anything you think will help
cheers Ian:)
Pingu101
28
the carries are part of the calipes so i think the hub's will need modifying
but cheers for your input;)
evans1089
196
Chesterfield
I have a set of alfa romeo GTV calipers i was going to fit. I made a fiat coupe 20v turbo disc fit the mk3 ibiza cupra hub. 305mm i think.. Was going to be a good set up, but don't have time to complete it anymore...
godzuki
Mk2 cupra & golf mk2 20vt
Sep 11, 2006
231
Newcastle upon tyne
the bolt spacing on fiat coupe (20vturbo) is wider than a mk3 cupra 130mm iirc
theey are threaded so a spacer plate is an option though.
weigh alot mind,don't drop them on your toe!
