Just got my Genden cable through (ordered at 14:00 yesterday!) and it's working great
Logged controller 01 Engine:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 6K0 906 032 AB
Component and/or Version: 1.8L20VTCUPRA R 0001
Software Coding: 11500
Work Shop Code: WSC 00000
4 Faults Found:
16501 - Engine Coolant Temp. Sensor (G62): Signal too Low
P0117 - 35-10 - - - Intermittent
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-10 - - - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Now I knew about the coolant sensor so I've ordered one (part 059919501a this right one)
The main concern is the 17536, system too lean. Does this point to a dodgy MAF?? I've cleared the codes and am going to clean out the MAF and hopefully it won't come back, if not I'm guessing I'll be getting the credit card out again
I'll do some logging when I've cleaned the MAF and fitted the temp sensor. Hopefully this should tell me if it really is the MAF. What blocks should I be logging?? 4th gear 2000rpm - redline??
Can anyone shed any light on the other 2 faults, 17947 clutch pedal and 18010 power supply.
cheers
4 Faults Found:
cheers
