I've only had my 2001 Leon Cupra for 3 weeks, so I don't really have a feel for it yet or know what I'm doing under the bonnet.
It idles really rough on cold start and searching the forums I see other people have had that too, but 3 days ago the engine warning light came on. It seemed to drive as well as before the light except occasionally it would feel like it was stuttering at steady speed.
Last night it got worse. It would struggle picking up if I gave it too much gas.
Again after searching the forums, today I intended to check for air leaks and also clean the throttle body. When I started it from cold with the engine cover off it looked like the engine was trying to jump out of the bay and sounded like a diesel.
After it had gone off fast idle it was so much better, but after 3 or 4 minutes the revs would drop and it sounded like it was struggling every 5 seconds or so, like it was being starved of air.
There was a noise which sounded like it was coming from somewhere around or under the manifold but I couldn't tell if it was an air-leak type sound or not, it could just have been a pulley or something else.
When I revved the engine it was ok, but would almost cut out when the revs dropped back to idle again.
Remembering the searches on here, I disconnected the MAF (if its the thing sticking out sideways off the big hose top left of the air box) and it ran ok for at least 5 minutes, including when revving and going back to idle again.
Was I right in guessing that was the MAF, is 5 minutes long enough to be conclusive, and could it mean something else is wrong or is it the MAF for sure.
Sorry for the long post but I'd rather give too much information than not enough in case something I think isn't important actually is.
