Yip, but perhaps not for long enough before I took the cables off the dash.Did you disconect the battery when you removed the cluster?
Looks like Vagtacho will be the easiest solution....
OK, perhaps it wasn'tWiring to the instruments is definately on OK
It really was one of those jobs which just kept getting worse!Sorry to hear you had so much fun. Mine did the trick and sorted all my woes. I never had an airbag warning light or any thing else. Just worked. I wish I had access to VAG-COM. Besides the airbag light, did you solve any of the problems you were having?
If anybody has the connector pin-outs I'd be interested to know what the top few rows of pins are for.
Makes sense. When mine wasn't working it wasn't quite plugged in correctly at the top, even though the latch/clip was fully home.When i had the connector appart the first row 1 and 17 were for the immob coil then there were a few spare maybe two or three.
I don't, but if you take off your fuse box cover you can see the connector going into the rear of the cluster.does anybody happen to have a picture of this connection?
Thanks for the table damo, typical the ones I need you can't get to
SUCCESS!!!
figured out how to do it WITHOUT removing the needles and stripping down to the bare board too, all u need is a needle nosed iron and some soldering skill NOT RECOMMENDED FOR THOSE WITH POOR SOLDERING SKILLS OR UNSTEADY HANDS!!!
managed to do all the pins so no more flashing oil light, water light or none existent fuel gauge car started first time and everytime since, gonna take it for a run as sometimes it would work then go off after 10 mins or so
i will write up a howto with pics and post it shortly (car is still in bits atm)
