Fault code 00258 Solenoid 1-N88, Help
Tom696
63
Pompey
Cheers rob,
Mine car is a manual, I think it might be the solenoid at the front of the engine on the EGR its making some high pitched noises I think this is the turbo charger waste gate solenoid valve??
Don't suppose anyone knows about these do they???
Tom
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
The wastegate solenoid is the N75.
If you think there are problems with the EGR or N75, you could try doing a output test on the engine controller. It will step you through it and you can hear everything working.
It will then show whether there are any problems with the outputs. N88 is definitely transmission, however, it could be something else throwing that out.
