Fan belt squeaking
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Hi guys, whenever i start my car from cold i'm getting quite a squeak from the fan belt, wd40 helped but it hasnt fixed the problem, can they be adjusted?
If i need a new one can anybody advise me where to get one on the net? thanks
________
Vaper Genie
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
i'm glad somebody replied :) i was just about to bump the thread, looks like i need a new fan belt
tbh for me its when i havent started the engine for about 12 hours or so, doesnt matter whether its in gear or not. it does go away after 5 minutes but its embaressing when my neighbours walk by in the morning :p
anybody know where i can order a new fanbelt online? thanks
________
Wanna_Play_Hot
g1
aha! i have the same issue, have you got yours replaced and how much did it cost? what are the consequences of not getting it replaced as im skint...
tkjeeves
Blue
Jul 13, 2008
333
oxford
i thinking you mean the auxilery belt not a fan belt, as all cars use an electric fan now. From what i recall i got mine replaced when i had my timing belt change and i remember it was £15-20.
You seeing any cracks or any sort of wear and tear on yours?
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
If you're talking about the aux belt, it could be the tensioner. £60 parts and 5-10 mins to replace if it is.
s10mph
VAG car nut
Mar 1, 2008
243
Thundersley
The aux. belt or V belt as VAG say will squeak after a few years, they will have a glazed look on the inside off the belt due to slipping and the only cure is to change it. Easy to change yourself for about a tenner. Sometimes the tensioner will need changing as well. The timing belt is called a Toothed belt by VAG.
s10mph
VAG car nut
Mar 1, 2008
243
Thundersley
I had mine replaced a little while back under warranty. That solved the problem for about 10 months. But now its doing it again. Really bad when the engine is cold. I was going to try a bit of WD40 the weekend but sounds like that didn't work. Any other ideas are welcome :shrug:
The only cure is to change the belt and to be sure change the tensioner as well.
tkjeeves
Blue
Jul 13, 2008
333
oxford
WD40 is not a good idea IMO as from as far as i know, the WD40 will gradually degrade the rubber on the belt over time making this worse.
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
yeah changing the fanbelt and tensioner fixed my problem, sounds much nicer now :)
hello mate can you describe the noise and its habits. i'm trying to diagnose a strange sound from my car. kindof intermittent warbelling sound. like a cute fuzzy extra terrestrial animal would make.
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
all i can describe is a squeaking sound which sounds more mecanical than like an animal, i could hear it louder than the enginge. i only got it when i started my car from cold, after 10 minutes it was fine. if you upload a sound i can tell you if it sounds like it
________
Ford maverick specifications
