Failed M.O.T Today
RabReith89
402
Aberdeen, Scotland
As above guys failed my mot today on high exhaust emissions... still not past yet
They tryed replaceing the afr regulator never made a diffrance, lambdas are reading fine.
Garage ran out of ideas, i only have a cat-back exhaust and the cat is looking a bit iffy so could the cat be fooked and causeing this???
Car is running fine, guy in the garage said with being remap ect could be causeing it???
Here is some test readings
FAST IDLE TEST
RPM ---- 2500-3000
NO CHECKED
CO 0.67% 0.30 MAX
FAIL
HC 54ppm 200 MAX
PASS
Lambda 1.01 0.97-1.03
PASS
NATURAL IDLE TEST
RPM---- 450-1500
NO CHECKED
C0 0.68% 0.50 MAX
FAIL
Any ideas lads
Rab
vngtx
ask other people with similar mods if theirs passed MOT with Vpower. try cleaning throttle body, and MAF sensor. tried vagcom on it yet?
Laura
Oil in the cylinder can cause higher CO2 emissions or a bad air/fuel mix. your cat takes unburnt fuel and converts it to CO2 and H2O, and turns CO to CO2 so technically high CO2 could mean your Cat it doing its job. It could also be worn piston rings, or sticky piston rings. If your engines got some miles on it then try some Redex to flush the cylinders out a bit. Oh and it's MURDO180 posting in laura's name incase anything i've said is absolute mince lol. keeping myself covered from a slap on the head.
RabReith89
402
Aberdeen, Scotland
Well in the middle of doing some research no luck so far...
Serviced my car on wed so plugs filter ect have been changed.
Will put some redx in to clean all the **** out see if that helps any, have noticed befor mot that some times the car can have a strong smell of petrol and i have been going thro a good bit of fuel lately
Did put the computer on it fault code 0327p came up???
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
right plugs?
Whack the old ones in if you have them.
check for leaks etc
but pouring chemicals in & v-power is useless.
RabReith89
402
Aberdeen, Scotland
New ones are the exact same as the old ones mate, noticed the other day when i took my splitter dv apart to clean it that the spring was snaped in half that would explain boost not holding.
Could this make my car run rich or lean???
So u think redx is just a gimmick then mate
RabReith89
402
Aberdeen, Scotland
Think am gonna try a new cat gonna go for a blueflame system with a 200cell sports cat need the dp and sports cat for when i fit the new ko3s turbo anyway.
Fingers crossed this works mebe not having a sports cat or decat has caused the inside of the cat to brake up inside with the extra power going thro??
RabReith89
402
Aberdeen, Scotland
UPDATE
Been to the local garage after fitting my new dv spring as the old one broke and did a other emissions test still the same CO 0.067
The head guy told me to try replaceing the 1st lambda sensor so ordered one and picking it up tomorrow so fingers crossed this is it if not its a new cat.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
does your car run any n249 etc bypasses?
does block 001 on vagcom show any movement on %?
if bypasses are done badly adaption will not work, ecu stops adapting = mot fail
saw it only last week on a local S3
solenoids plugged back in and hey presto adaptions worked and emissions worked. (it also had a slow main lambda probe, which was'nt helping)
RabReith89
402
Aberdeen, Scotland
Yea mate car is n249 bypassed, dont have vag-com to do any logs :cry:
See how u have 2 valves on top of engine, 1 which is leading to actuator ect and the other which sits just pluged in, well the 1 which just sits pluged in i have no valve there it melted.
Could this cause this??
Thanks Rab
