Exhuast querie..
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
on the Mk2 Ibiza's .. is the rear exhuast hanger *Rubber* a stealer only part??
mine seems to be stretched and its causing the box to vibrate, and is really annoying at time... Ive looked on 'Vag-Cat' and it shows it on there as a 'complete unit '
TIA
KENWA
Don't Crash It Hurts
Sep 5, 2005
87
Hi Mate,
The Rubber is bolted to the hanger and is one piece only. Bolts onto the chasis via two tap bolts. I know this because ive just replaced mine with 2 shiney new magnex ones.
Be carefull not to strip the heads when removing them. I ended up grinding off and drilling the last bolt out.
KENWA
Sep 5, 2005
87
Sorry buddy,
call me glum but how do you mean a stealer only part??
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Stealer= dealer ( *affectionately known as due to price hikes*)... certain parts can only be purchased through dealers.. but it seems the part I need CAN be purshased elsewhere too..
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
i dunno, is there not a clamp on the exhaust and then one on the body, both joined by a rubber? i havent ever looked at mine so i wouldnt know
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
nahh... the clamp that bolts to the body has the rubber already on it as an integral part if you like!?!?! it then just has the 'holes' in to *push-fit* onto the hanger thats weled to the back box..
Sep 20, 2006
756
Birmingham
Im not sure if im thinking of the right part but is it the rubber thing that the back box hooks on to? Mine split awhile back and it got replaced by one for a transit. So (if we're talking about the same part) you dont need to get it from the stealers.
KENWA
Sep 5, 2005
87
cable ties might melt from the heat. Better to use a hose clip. You could cut the old rubber off and hose clip a new universal rubber to the bolted clamp.
