Model Year 21/22 Error: selector lever
May 2, 2024
Hi all,
Started getting message: Error- selector lever. You can drive on. Please visit workshop.
V1 1.5 dsg Formentor 2022 plate. Doesn’t happen on every journey but this morning didn’t clear even when I turned car off and on again.
Has anybody else had this issue? Is it something that should be covered by manufacturer warranty? Any advice would be appreciated
tomek_olo
Cupra Leon ST VZ 2.0 245 DNPA DQ381
Jan 28, 2022
130
41
Aug 24, 2023
SOLUTION WORKING
I had the same issue and followed the video. You dont even have to cut the plastic inside you can take the 3+2(side) screw out and slide the plate in front to see the solenoid. With 2 small screwdriver you can push the side teeth and than take out the solenoid. Tighten the contacts + contact spray and that s all. Thank you for the solution!!!!
