At the time of the picture I had 6000K HIDs in my fog lights, mate. Now I have Osram Nightbreaker Plus fog light bulbs (normal halogen) and will be going for Osram Cool Blue Intense next since it's brighter.
I got all the bulbs delivered but I can't get near the sidelights etc to change them, does the the headlight unit need to come out? I read that a few folk had managed it with just major knuckle scrap page but I'm having no joy
Nope, headlight doesn't need to be out! The sidelights are mega easy.
Just pull off the circular plastic cover that is behind the sidelight and main beam light. You should be able to locate the back of the sidelight bulb holder, it is circular too, and on it is a small tab. If you push the towards the centre of the bulb holder it will release and you can then just pull the holder out. You then remove the bulb, place the new one in, test it to ensure polarity is the right way round, and it doesn't error. I then suggest putting it back in the headlight when the sidelights are on as it means you can look inside from the front of the light to locate the hole easier.
I have purchased the number plate bulbs from these the one listed and they still bring up errors, save u self the £15 and buy the ones for a few quid, don't see the point in paying over the odds if you are still going to get the error codes.
