Error codes on my Cupra
Jul 10, 2001
972
Bedfordshire
When i arrived at work this morning my engine management light on my Cupra came on.
Can anyone point me in the direction of a guide or tell me how to:
1. scan for faults on VAG-COM so i can see what the problem is. :confused:
2. clear my ECU of the error codes. :confused:
This'll be my first time using VAG-COM and it seems a little daunting but nevertheless i would like to learn the basics and know how to use it.
May 2, 2006
2,758
open vagcom
go to engine
click fault codes
- ilf you want to clear them click clear
or
click on autoscan to scan absolutly everything
972
Bedfordshire
Ok after hooking my car up to VAg-COM this afternoon my car is spitting out the following codes at me
16795 P0411 Secondary Air Injection System: Incorrect Flow Detected
17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
any ideas what could be causing this, or areas i could check to see everything is ok.
Is there anything i can do on VAG-COM to check what state my car is running at?
Oct 17, 2006
893
Walthamstow
Measuring Block 3 - Mine was reading about 130 G/S @5720 revs and consider that to be fine - my car is chipped to about 180ish BHP -
hope thats some sort of guideline.
