EPC warning light
Banksy 1
ibiza cupra
May 27, 2007
165
Stoke-On-Trent
only had me cupra for about a week and i was driving down the road the other day when the EPC warning light came up on the dash, read the manual and it says it is the accelerator pedal fault does any1 no what will be the cause for this to come up?
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Brake light switch or clutch pedal sensor normally. If you change them make sure they are set up properly or it will just come back on again.
Or if you were left foot braking that will bring it on aswell so dont!
Big_A_Cupra20vt
184
margate
mine is on as i changed the clutch pedal clip and must have knocked the sensor every now and again i mage to kick the clutch pedal and it goes off for a while. if that sensor is on does it stop the turbo from boosting properly? only someone told me it does, mine seems fine though.
Banksy 1
ibiza cupra
May 27, 2007
165
Stoke-On-Trent
just plugged me car in today and it came up the clutch pedal sensor as you lot said. cleared the code then checked the sensor only to find that it had come out of the clip on the pedal bracket, clipped bk in and ok now with no cost to me!
verymooseymoose
My 1.4 Mk3 has a similar problem, the EPC light keeps coming on and it then limits it to 3000 revs, or sometimes cuts out. Im plannin on getting it diagnosed, but can anyone tell me if this is the same problem? (Clutch sensor)
verymooseymoose
if its a clutch pedal sensor you shouldnt hip limp mode mate, might be something more ominous like MAF etc.....
Sorry, whats a MAF? Not really sure on technical terms, lol. Was thinkin of getting SEAT to diagnose it? Do you think this is a good idea? Thanks
dave_6
193
Essex
try and find someone local with vag com to see if its the maf
check what fault codes you get
my local seat wanted £40 to hook up to laptop for half an hour, harsh
found someone local to me by posting on this site and checked my codes that way
verymooseymoose
Thanks, if anyone in cheshire/manchester has one and is willing to help thatd b great. But what is a maf?
savbaby
Hi, Mine has just done this also. I was sitting at some lights and when went to pull away car cut out, took few attempts to get it going and then limits to 3000 revs. When I turn it off and on again it resets and all is ok but every so often it will bring the light on and limit it to 3000 revs again. Does this sound like just a sensor or something more serious? I cannot get to the garage until Thursday:help:
teknow
138
Great Wyrley, Walsall
Mine does this limit to 3000rpm too .. bloody annoying.
I've posted several times bout it but still no joy. There is a posting where a guy reckoned that cleaning the G28 engine speed sensor (one that reads flywheel) sorted it out.
Other suggest MAF .... possibly (but unlikely) the engine coolant sensor?
Let us know ... the EPC light doesn't come on and on mine it usually happens about once a week and usually after 8-9 miles when the engine has just warmed up.
Just turn the key to off and then back to position before the starter is engaged and the car runs absolutely fine!
Mine has been like this for 2 years now.
savbaby
this is exactly what is happening to me and what i am doing to clear the problem. I Think it may just be the sensor , will get it checked but not so worried now. :D
teknow
138
Also ....
... I called a Seat dealer and they said they'd recently had one in and it turned out to be the MAF [ and throttle body] ....
... I asked how much the guy paid for the repiar ...
"I shouldn't tell you this but ... £850!!!!!!!!!!"
[:@] They really p me off.
