EPC light when going fast
Graxxel
hey guys.. I'm battling on with my biggest nightmare job yet.
My leon Cupra 280 runs perfect in almost every way. However on a motorway or anywhere with enough space to really open it out, Once the engine is under all it's load at 95+ throttle, I get an EPC light come on and then then it drops a cylinder. it appears to be worse in cupra mode.
If I back off straight away the epc light stays on until the car is turned off and back on.
If I continue to hammer the car while it's miss firing it would permanently drop that cylinder until the car is restarted. (I am assuming this is limp mode).
I changed the plugs and coil packs. My scan tool doesn't show me a code for the EPC light.
once the car has been restarted you would never know there was a problem... Until you really let it rip in some open space.
I can't find any kind of pattern for when it happens. Such as temperature or whatever. it is just when the car is under maximum load it wide open throttle...
If anyone has any real advice or has delbt with this before, You're help is greatly appreciated.. I just want my Cupra back :(
Legojon
I only wanted a remap
5,313
2,745
Does your scan tool show you misfire count? I'd start with misfire count to see if its maybe an injector, look at fuel requested vs actual see if its a fuel pump problem. MAF, diverter valve - although I don't recall those bringing on the EPC light.
Graxxel
Hi bud, thanks for the reply. unfortunately it the missfire count doesn't seem to work for the newer VAG cars. I've mostly driven Nissans and stuff before so my scanner worked great for them. doesn't get along with vags so well :/ do you think this is basically not worth even looking into until I have had the car out on a worthy diagnostic?
Legojon
5,313
2,745
Yeah, I think it might be better hooking it up to a VAG specific scan tool first. Otherwise you'd just be throwing money at good parts. I've also noticed that there's often discrepencies between tools (eg, some pick up codes others don't and vice versa).
raflo83
74
Wroclaw, Poland
I have similar problem, but....on stage 3. The reason are misfires. It cuts off cylinder at high revs with WOT. Coils, sprak plugs, pcv replaced. Injectors removed and cleaned. Quite a lot of carbon build up in intake - cleaned. Autotech Fuel pump insert installed. No matter If I have stock map or st3 i can see random misfire on all cylinders, but on stock I can’t feel anything and car runs perfect while on stg3 misfires are more frequent what cause at agressive acceleration cylinder disabling after gear change. It might be due to the incorrect map, but even on stock misfires exist. My feeling is that If i do not solve misfire on stock map i will not get proper st3. Who experience misfires on stock? I’m checking it using misfire counter on vcds. What else can cause misfire in this engine and how to check it?
Jan 20, 2025
I’ve started having this problem recently. Cupra 280 2014 stage 1 and at around 110mph the car will cut power and throw the epc light(car is performs normally after this no limp mode). Code that comes up is P039B of which clears with no history after restarting the car. After some searching it is high pressure in a cylinder but can’t find any more than that. Anyone have any advice or suggestions ?
nd-photo.nl
3,870
126
The Netherlands
youtube.com
I was able to find this:
Possible symptoms:
Irregular running
Insufficient traction
Possible causes:
Ignition not set correctly
Injection not correct
Camshaft timing not correct
Compression springs worn
Valves not closing properly
Leak in cylinder head
Wiring and/or connections defective
Pressure sensor
Engine Control Module defective
Possible solutions:
Check ignition
Check injection
Check camshaft timing
Check compression springs
Check valves for wear
Check injectors closing
Check / repair wiring and connections
Check (measurement value blocks) / replace pressure sensor
Check (measurement value blocks) / replace Engine Control Module
Reactions: Benstanden10
mty12345
4,001
617
bristol
What fuel are you using?
Code comes back as cylinder 1, maybe pull the plug and look at the condition of it. What plugs are you using? Could be that you need to run a grade colder, hot plug may be causing pre-ignition.
Jan 20, 2025
Using oem plugs running shell V power only ever run 99+ octane fuel.
thanks for the reply appreciate it
mty12345
4,001
617
bristol
No worries mate. There was a technical bulletin regarding this code, but it was only for later models. See attached pdf
Seeing as it happens at high load (110mph), only guess is like i said earlier, a hot plug causing premature ignition of the mixture in that cylinder. Colder plugs are usually only required at stage2+ but if you can't find another cause then might be worth trying a colder set. As said in the article below, worse that will happen with a cold set is that the might get carbon build up causing a misfire. That would be self-evident by removing the plug and checking
  • MC-10122118-9999.pdf
