Mudz
As above I fitted a new engine its a 1.9tdi 110bp, with a different engine code but practically identical, i changed the fuel pump so it used the original one, now it will not start it cranks over but does not start i loostened the flue lines to injectors for fule but nothing is coming through.
i also checked the fule pump when putting the ignition on i can hear slight clicking noises in the fuel pump, is this normal? and hear like a humming sound, kind of like a speaker on full volume when not playing any thing,
lastly i put vag com on it (cheapy one from ebay) it says 1 fault found instrument cluster memory needs resttting, wht ever that means,
can anyone help
thanks in advance
can anyone help
thanks in advance
