davecupra16v
Hi all,
Ive got a mk2 ibiza 2.0 16v abf and when the engine is cold for example first thing on a morning, the engine doesnt seem to idle very well it just keeps bouncing off the revs as if im blipping the throttle, i really dont know why this is happening, oh and when i set off its just a touch on the flat side, seems to be a little bit down on power. Once the car gets up to temperature its absolutely fine!
Any ideas?
My Cordoba was running the same mate, now its not running!
Il update as and when i get to the bottom of it, can you please do the same?
Seems there are so many possible causes, just need to get it running first!
hmmm iv just bought 1 n its doin that maybe its just cold ? :)
sounds like the idle control valve mate may need a clean or replacing. or the cold start injector is a common problem on the 16v. from what i can remember from past experience.
the other thing to try is the coolant temp sensor.
it might be faulty, causing the ECU to think the engine is 'hot', and therefore under-fueling it when it's cold.
If the idle is Ok when the engine is warm, then I would try the temp sensor first.
