Engine Diagnosis Light comes on and stays on
Martin T
Has anyone else suffered with this problem?.:shrug:
Car is Ibiza Mk4 TDi 130 Sport
Noticed the light come on today engine seemed to run fine.
Switched off for about an hour, started up fine again ie no light on, ran to friends home fine, switched engine on after about 2 hours problem back.
Ran home with light on seemed to run fine :confused:
Does anyone have VAG COM and Lead in Littlehampton area as would really like to check this out, before taking it to the stealers
Cheers for any help.
Aug 1, 2005
2,695
Cullompton . Devon
It`s an engine warning light which comes on if the ECU thinks there is something wrong with your engine. It`s there for a reason :doh:. Get a friend with VAGCOM to check the car or take it to a garage for them to check it for you.
kghelani
I have a Ibiza FR TDI 130 where the diagnosis light is on and the coil light is flashing, this started yesterday. Yet the car still drives well. It has done 47,500 miles. Any one else had this problem? I will be taking it to garage on Wednesday.
Bricktop
Yea mine had that last week it was a coil to the spark plugs. It will run but you run the risk of it damaging your cat!!!!! thats if you dont get it replaced soon it cost my £40 for one coil it a common problem with ibizas
Tricky Red
75
Mine came on and it was down to the water temperature sensor. Replaced and all ok now.
rocky2008
Buy Cheap Buy Twice!
Nov 16, 2008
1,029
North-east
it could just be a faulty sensor, i drove around with mine on for 2weeks as i got told it was the lander sensor that was faulty but it didnt appear to effect the cars performance.
kghelani
I got it sorted took it to a VW specialist and don't know if it is true or not but it was down to the cam belt and replaced along with the water pump and service drives really well now. Thanks to everyone for their advice
