Engine cut out??
J4M3S
Yes it is and No you cant
Jul 17, 2007
97
Belfast
www.s44gan.com
Hi Guys, slight problem with my cupra over the last couple of weeks.....
it is randomly cutting out.
sometimes i could drive a good 50 mile of mixed driving and have nothing
then all of a sudden i could slow down to about 10mph and it would just die, electric would cut and engine just stop along with power steering etc.....
anyone know what this could be?
any help appreciated.
thanks.
superleon1
Hello mate - I had the same problem with my previous Leon, and I dropped it to the dealer....it was cutting out as I was slowing down to go around corners etc or stopped at lights. The dealer just used some of that engine cleaner stuff and charged me a 100 euro! You should try that maybe...you should be able to get it in Halfords for about a fiver! Good luck with it mate.
J4M3S
Jul 17, 2007
97
Belfast
www.s44gan.com
mods are......
revo stage2 remap
milltek turbo back system
green dynatwist induction
ths downpipe and decat
4.0bar fuel pressure regulator
forge front mount intercooler
forge 007 dump valve
this has become a big problem now :(
done the engine flush and while i was at it i changed oil and oil filter but was out tonight and cut out twice....
it has now got worse to the point that when i am restarting i have to pump the accelerator to get it going again.
what you think?
only thing i can think is that i have a small blow out just after the down pipe somewhere, but would this effect it?
thanks for the help.
teknow
138
Great Wyrley, Walsall
If it just suddenly stops ... like an electrical fault (ie no spluttering etc) then I'd change the Engine Speed Sensor. Costs £60. I paid £50 fitting to have mine replaced.
other things you might notice with this fault are 'jolts' because sometimes the sensor cuts and then starts working again in a fraction of a second.
You might get limited to 3000rpm 'limp mode' too. There will be no EPC light but if you put the car on VAG-COM it will be writing an intermittent fault on engine speed sensor message.
The Seat main dealer was usless said there were no fault codes - when the independent used VAG-COM there was and he printed it out to proove it.
Watch out because some are held on with 4 bolts and some have 5 so best to have a look before you order the part.
I wasted 18 months of my life on this problem.
If it only happens when you are slowing down or pulling up then it could be the throttle body is full of sh**e.
cupra247
hey i had the same problem when i got my cupra. it was a sensor on the drive shaft that had went. its just a saftey thing fot the car it shuts it down in otherwords.
pickie
222
not much help, but my Mk3 cupra cut out on me the other day, as i was slowing down at a roundabout, like you said all the electrics went out dead :( and now i have the ECU light on, which i havent got around to finding out what it is saying, but fingers crossed it hasnt cut out again ( 1-2 months now )
