engine conversion
robbyd
ive decided think im gona stick with my 2.0 16v and have a play around with it instead of going the turbo route...just yet!
>Going to invest in a decent set of cams> any suggestions as to what would be best?
>sports cat
>fuel pressure boost valve
>uprated manifold
>pipercross viper induction> are these actually as good as they claim to be?
>and finally ecu remapped
all help and any other suggestions are greatly appreciated!!
robbyd
yeah i read elsewhere on here someone who has a 2.0 16v is running 190bhp they have schrick 268 cams. also a tsr 4-1manifold would i not be able to find a sports cat to fit this without having to weld it?
also would i need to uprate the engine mounts?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
You'd have to weld the cat on yes....
I thought the maximum on std induction was about 180bhp... then you need jenvey's
robbyd
whats jenveys? you'll have to excuse my ignorance im not too hot on seats...just yet
robbyd
this is the one im on about if it helps
Rally Slag Ibiza Cupra Sport 16v: Ported & Polished Head : Dr Schrick 268 Cams : Re-map : TSR 4-1 Manifold : Uprated Clutch : De-Cat : Brembo Calipers : Ferodo DS2500 Pads : 305mm Gooved Discs : Exhaust System : Pipercross Vector Induction Filter with Heat Shield : Vibra Technics Engine Mounts (Fast Road) : B&M Racing Short Shift : FK Highsport Coilovers : Compomotive MO : F2 Rear Spoiler : Window Tints
190.2 bhp @ 7002 rpm
robbyd
ahhh now i see its a conversion kit!
if i fit this is there anything else i need to alter?
robbyd
hmmm sounds like a pain in the a*se!
maybe its back to the turbo then seems to be the more versatile of the two engines!
robbyd
will have about 3grand for it by january just tryin to se whats best at the mo
ibiza_95
1.8T MK2 Conversion
you can buy a turbo kit for the 16v
just search using the function and itll bring it up. youve got to then consider mapping for the turbo, and any internal upgrades, but it is still an option
EDIT:
http://www.seatcupra.net/forums/showthread.php?t=92802&highlight=turbo+16v
Thats the thread
'''ToledoRaj''' think i read hes spent 2.5k turboing it tuning etc and has got 260bhp
robbyd
probably best to get 1.8t and modify it then within reason so as not to be needing to alter internals. have some £££ left for respray then
(beeza gti)
mk2 golf 20vt
Aug 22, 2004
272
porthcawl,south wales
thats daves car ur on about,all the work has been done by stealth racing,cost a bit but worth every penny.you cant beat a good valver;)
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
if you've got 3grand to throw at it then sell the MK2 add the three grand to what you get and get a mk3 cupra and the later car with the better features. I have a 16v and when its on song nothing beats it for fun factor, and its a really involving drive
