Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
as title said , is it possible? I think that my compression may be to low and thinking of putting standard pistons back in but may bore to 82.5 @ 9-1 if possible without removing engine
had rods and be pistons fitted , bought be pistons from state
Standard bore but they are meant to be 8.5 - 1 but mike thinks they are lower due to the amount of timing etc he is able to run. Boost is at 2.1 now with 51c max inlet temp and still no pull back
Obviously if its "too" low then I guess it'll be sluggish off boost - what does it drive like? If it drives OK and you can dial in loads of timing I don't see the problem
You can't do a proper rebore/hone in situ. Maybe a light hone if the crosshatch is in place and standard size pistons but is certainly not something i would want to do!
