Engine bore with out removing engine
G12MO X
84
as title said , is it possible? I think that my compression may be to low and thinking of putting standard pistons back in but may bore to 82.5 @ 9-1 if possible without removing engine
caney
600
engine out,block removed then off to be machined unless they can fit your car in the vice as well:lol:
G12MO X
84
compression too low because??????? of what?
std bore now is it?
had rods and be pistons fitted , bought be pistons from state
Standard bore but they are meant to be 8.5 - 1 but mike thinks they are lower due to the amount of timing etc he is able to run. Boost is at 2.1 now with 51c max inlet temp and still no pull back
stewbie55
No longer a Newbie
Aug 12, 2006
427
Is that a bad thing?
Obviously if its "too" low then I guess it'll be sluggish off boost - what does it drive like? If it drives OK and you can dial in loads of timing I don't see the problem :shrug:
INA
Garrett Super STAR!
Dec 8, 2007
www.inaengineering.com
Will always have to remove the engine if you are looking to bore or even hone for that matter.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
sounds too low.
just get same bore higher CR pistons then. 9:1
ryan_s3
1,270
You can't do a proper rebore/hone in situ. Maybe a light hone if the crosshatch is in place and standard size pistons but is certainly not something i would want to do!
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
i know, not clever imo.
i did see him do it wrong once. left the machine running while he did something else and it hit the crank...oooppps
INA
Garrett Super STAR!
Dec 8, 2007
And then when you break off the oil squirter nozzles you will have to remove the crank to get @ them properly.
HTC
Sep 2, 2004
421
Flex-hone possible in situ. Wouldn't be able to go further than that i would have thought.
