Engine Blown???
Capital D
Ive got a 2.0 16v ABF engine and the auxilary belt has come off due to a pulley coming out the side of the engine. I think its the pulley connected to the crankshaft. I know the timing is done with the cambelt but could this of had any effect on the crank? A mechanic is trying to say its cheaper to replace the engine because the crank has gone altho he hasnt stripped the engine to find out. As far as i was aware you cant tell without stripping it down. so i think he is trying to pull a fast one.
Any input would be appreciated
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
the pulley is bolted to the crank (same as the timing belt pulley) - and if that's stripped then a new crank is needed
given you can pick serviceable ABF's up for £250, you may as well buy that - have it stuck in (less than a days labour) and sell the old one to recoup your costs.
Capital D
As far as i can tell the auxilary pulley has just fallen away..Is this a common problem? Have you ever known of this to happen before and is it likely to have done damage to the crank?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
never seen it before, likely the bolts have just got loose.
easiest way to test is to put new bolts in :)
