This is my old car and the
problem was aparent when I sold it to him (he knew it had a
problem)
The lambada sensors have been changed and he has put the OEM air box back on just in case. (I don't think it is this though because the EM light has come back on)
The exhaust was a powerflow pile of $hit so that was taken of and sealed up properly them put back on properly.
The N75 valve is new and it has a Forge DV. (so it can't be the DV causeing problems)
The car seams to run fine (boosts too 17.8psi) for about two or three days after having the codes cleared, then the car will only boost to 8psi and the EM light comes on.
Biglee (the guy that bought the car) only lives a few miles from work and therfore the engine probably won't get that hot.
I think that the
problem only arises when the engine is warm.
I belive that the
problem could be split boost hose that only shows up when the engine is hot and the rubber hoses expand.
What do you guys think?
