Electric tailgate creaking noise
Tha_Matt_Man
34
14
Belgium
Hi all,
Is this sound of the electric tailgate normal?
It's some sort of creaking sound.
It has always made this sound, it's only until now that I've noticed that only the right side makes this noise. The left side does not.
So now I'm thinking it's not normal... Any ideas, also what the issue could be?
Car is still some months within warranty.
Karbonfaiba
185
117
Hampshire, UK
Mine doesn't creak at all, but it has started making a small squeak right at the end of the travel to open.
Yours might be caused by under lubrication or screws over torqued. But sounds like it could also be rubber touching against somewhere it shouldn't.
Really need to use your ears on issues like this, is the creaking happening on both sides equally? Can it be pinpointed? Pull the liftgate by hand, does it still creak? etc.
dazed
84
54
Interesting, mine is also making a small squeak/creak at the end of its opening, just on the left side. Sounds like it needs some lube
