This is geared around the engine in my Passat but the theory should apply equally to the PD TDIs in Ibizas/Leon etc.
I'm trying to understand the operation of the EGR system, to see if the hissing noise I'm hearing coincides with EGR operation.
First, I assume the EGR valve opens under zero or very light throttle conditions to allow some exhaust gases to recirculate into the intake.
Then under any acceleration or boost, the valve closes off.
Second, I'm assuming the EGR would be designed to only open when vacuum is applied - so if the vac pipe was damaged it would fail "safe" and stay closed. In other words it needs constant vacuum to keep it open at idle/low throttle conditions.
So - there must be a constant source of vacuum supplied to the EGR, with a control valve somewhere in the middle to restrict the vacuum applied to the EGR valve as necessary.
Does anyone know how the control valve works - does it just "block" the vacuum from reaching the EGR valve under acceleration and that's that ?
I hear my hissing noise start (after a very short delay) whenever I accelerate, even when acceleration is gentle and at low revs (before the turbo spins up).
Then when I lift off it goes away.
In my mind this seems to coincide exactly with the EGR operation, does my theory sound correct ?
In which case the hissing sound could be related to the control valve letting air in, or a leak in the pipe leading from the vacuum source to the control valve.
I'm wondering whether this could all be related to the poor mpg I'm getting too.
I doubt if it's related to the VNT actuator, as I've sat in the car at idle and cycled the VNT actuator with vag-com in engine bock 11 - and heard no noise.
Thoughts ?
Thanks for reading, hope I haven't bored you to sleep
Thoughts ?
