egr delete valve
stu 157-330
80
West lothian
hi, since i've been having trouble with my egr valve.. i'm considering a delete valve instead.. just thought i'd ask if this is good idea..
cheers
stu
Jul 23, 2008
720
Manchester - UNITED
Loads of people run EGR delete pipes on here mate with aparently no issues whatsoever, i personaly dont think its a good idea to remove the Anti Shudder Valve but each to there own.
OLDOILER
1,292
Wiltshire, UK
cheers stu
Been considering it myself, but will wait for the stepper motor to pack up first! about £58.00 from allards [mine is a 170 remapped]
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Anti-shudder valve and EGR are both moved by vacuum actuators. No stepper motors to be found - the EGR is on the hot side, and the anti-shudder valve is a simple on/off operation.
ucchockey
92
lichfield
i have blanked off the exhaust inlet on the egr valve. This way u still have the anti shudder valve and it looks the same from the outside if you like the oem look. just make a thin gasket out of a biscuit tin lid and bolt it in.
DEAN0
Old Git
Feb 1, 2006
5,356
347
Preston - UK
I tried all ways to take out the EGR valve but they all fetch up a fault light.
Remove the vac line to the EGR & plug it = fault light
Blank off the feed pipe from the exhaust = fault light
Combination of the above two = fault light
I read this write-up and it looks like the best of both worlds - free flow EGR body with the anti shudder valve still working.
http://forums.tdiclub.com/showthread.php?t=75682
DEAN0
Old Git
Feb 1, 2006
5,356
347
Preston - UK
edit - although I'm now tempted by just the biscuit tin gasket idea, is that safe? Doesn't it get affected by the heat, what temperatures are the exhaust gases out of a PD150? :)
I have heard that people block the end near the EGR with just a gasket material plate.
If you have it blocked - there is no exhaust flow through the pipe so no heat is transfered.
