Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Loads of people run EGR delete pipes on here mate with aparently no issues whatsoever, i personaly dont think its a good idea to remove the Anti Shudder Valve but each to there own.
Anti-shudder valve and EGR are both moved by vacuum actuators. No stepper motors to be found - the EGR is on the hot side, and the anti-shudder valve is a simple on/off operation.
i have blanked off the exhaust inlet on the egr valve. This way u still have the anti shudder valve and it looks the same from the outside if you like the oem look. just make a thin gasket out of a biscuit tin lid and bolt it in.
I tried all ways to take out the EGR valve but they all fetch up a fault light.
Remove the vac line to the EGR & plug it = fault light
Blank off the feed pipe from the exhaust = fault light
Combination of the above two = fault light
I read this write-up and it looks like the best of both worlds - free flow EGR body with the anti shudder valve still working.
edit - although I'm now tempted by just the biscuit tin gasket idea, is that safe? Doesn't it get affected by the heat, what temperatures are the exhaust gases out of a PD150?
I have heard that people block the end near the EGR with just a gasket material plate.
If you have it blocked - there is no exhaust flow through the pipe so no heat is transfered.
