Egr delete guide
Badger
2,888
7
Newcastle, Staffs
Just block both pipes with a screw and zip tie to secure it in and that's it. Just tuck those pipes away for safe keeping.
Depending on year, you'll have to get the EGR mapped out to stop a EML appearing.
Jonnyp14391
66
Simple as that then lol? Is this how you did it and had no problems? Is the fitting of it straight forward I already have EML on anyway lol glow plug problem but there l changed but it's still on
Badger
2,888
7
Newcastle, Staffs
That easy!
Though, the mapping out of the EGR, I did myself after a little learning.
Originally replaced with a Darkside EGR Delete Pipe as my old EGR was leaking however, found my engine shutdown rough due to the lack of ASV (anti-shudder valve).
That was replaced with a fully working EGR valve just blocked off and unplugged.
Actually still got that EGR delete in the shed...
Jonnyp14391
66
You legend thanks dan doesn't look too bad how do you find it without the asv? Benefits outweigh the cons?
dann2707
MPG Hunter
Sep 9, 2013
217
Leeds
Hiya buddy, you're welcome!!
The lack of asv doesn't really bother me. It's sometimes louder than other times but it's not bad at all. It wouldn'tmake people turn their heads loud. Just sounds a little bit rougher than normal, a bit like how mine sounded when the dmf wwas dying and turning off.
I would with out a doubt say it's worth it. The egr is just bad news altogether.
An often over looked point to the egr is that it negates the effect of the intercooler. You're cooling down your air so it makes it more dense with oxygen then by subjecting it to the hot gases from the egr you're making them hot again!! So you're losing power and mpg with it enabled.
Egr delete removes hesitation too improving pickup :)
Jonnyp14391
66
Ye there not exactly quiet cars anyway lol it's had a decat so I doubt it will
Make much difference , ye it's on it's 3rd turbo now I'm guessing getting shut of egr won't be a bad thing then thanks for help will get one ordered
Hawkesybaby
What difference does it make to remove the EGR???
Noob question lol
Jonnyp14391
66
Mines the pd130 but it's a BLT apparantlt what egr delete do I need? And does it make a difference that I had a new turbo put on lol? Still a pd130 turbo just a garret one.
Confused, it's an 06 plate ibiza fr 1.9tdi
Jonnyp14391
66
I know I had a glance I got to by darkside it was a two piece delete and you need to delete the cooler pipe? Anyone done this or is it just an aesthetic thing?
Apr 12, 2010
635
you can leave the cooler bolted to the manifold and with its water pipes attached. I removed it and rotated one pipe and joined it to another above the gearbox. Been fine for 20k miles
