EBC disks and redstuff pads
STEVEO@CYMRU
Lucky 7
Oct 19, 2003
310
CAERPHILLY S.WALES
well i fitted these about a month ago and although they brake well they are the noisiest brakes i have ever had they make a constant high speed clicking (like when you put a playing card to a bicycle wheel) even when i aint braking (does that sound normal) have taken them to 3 different garages to have them checked and all have said that they are fitted just fine. Ebc say that they should not click when moving only breaking and that the runout is wrong on the disc but have had this checked also and its within what ebc recommend ... all in all i aint very happy ... the noise is so bloody annoying:(
does anyone know the part numbers for the ebc redstuff so i can check that they are the right pads
i have a 2001 seat leon cupra with the 312mm discs
thanks
STEVEO@CYMRU
Lucky 7
Oct 19, 2003
310
CAERPHILLY S.WALES
its both front wheels the last garage i went to seemed to think that the noise was coming from the caliper , so they took it apart and put it back together but the noise is still there , i measured the ebc pads up against my old tarox pads and the ebc ones look about a ml smaller cant put them back in as they are knackered. i emailed ebc to ask if they had any ideas and all they could say was that they are in correctly fitted (so that would mean that 3 garages are wrong ) and one of them was a vw mechanic . also asked if there where any shims to go in them but was told no
daveyonthemove
Smile if you like SEAT's
May 14, 2006
1,519
Wrexham
How long have you had them on? What sort of milage?
If they are faulty you may be able to get an exchange as they should have some sort of warranty.
You have PM btw
ringer
LEON CUPRA
Sep 2, 2007
64
Isle of wight
i have the same set up off brakes as you mate,i dont get any clicking,just when i brake from speed,i get a very loud whooshing noise!!
i brought the car with the set up so i dont know the part number but clicking really dont sound good.
does the pads move at all when in the caliper?? might just be slight but when driving,it will move hell of alot
STEVEO@CYMRU
Lucky 7
Oct 19, 2003
310
CAERPHILLY S.WALES
i have had them on for 580miles and am still taking it easy , this is my second set as i sent the last ones back because of this noise and was sent a new sent only for the noise to still be there. i got no probs with the noise when braking and hopefully it will quieten down but its constant
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
turbo grooved disks?
wide grooves can make the louder noise.
cornering loading up the setup so things touch.. bending hub etc
mikesw
I had the turbo groove discs / red stuff pads on my LCR and they did the same, clicking constantly - only really audible with window open though.
And braking hard made a loud noise almost like warped discs but without any steering shudder.
Sold it now so never worked it if this is 'normal'!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
TG disks have a very wide groove, which is the noise... and louder when used and hot.
Ultimax disks are narrower multislot disks and what I personally reccommend for road use. quieter function
Apr 24, 2007
985
W. yorkshire
snap i am getting the same thing and im stupted for an answer too.
but i have yellow stuff rather than red
Avant4me
359
Bristol
Badger
I take it you are offering these for sale? i am just about to buy Red stuf pads but have been looking at discs as well. Could you give me pricing please for 2001 LC (AUQ) 312mm brakes.
Ta mate, you can PM if you don't want to post prices
STEVEO@CYMRU
Lucky 7
Oct 19, 2003
310
CAERPHILLY S.WALES
thank you lord im not alone on this ebc say they have never heard of this problem but on searching the net i have found quiet a lot of people with different cars on different forums who are having the same weird noises i am , and they are all using redstuff pads with ebc discs , so once these are worn out i wont be buying them again
ajay_parekh
got the same problem took the caliper apart cleaned it put some copper grease where needed and it still makes the same noise. everyone keeps saying it needs to wear in but ive done over 600 miles and the red bedding in layer worn off dont know what to do
