Ebay cable
Jamie123
123
I have now recieved my cable from ebay and it looks good. The thing is i cant get it to communicate with the car and laptop. I have read the sticky but it wasnt really clear what i had to do.
When i go to options in vag com and select the ports, only COM3 comes up as ok but at this point i dont have anything connected to the laptop, anyway what could i do to get it to talk to my laptop and my car?
Thanks a lot
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
is the cable usb or serial, have you removed all com ports from device manager and redetected the hardware/rebooted after? were you trying vagcom with the ignition on?
Jamie123
123
Wow, ok so i seem to be doing this all wrong then lol.
First of all it is a USB lead. How do i remove the com ports from the device manager and why would i want to do this? And i didnt reboot after!
Also i think i was trying vag com with the engine running, is this wrong?
Jamie123
123
I dont really know what i have mate, tbh i didnt think you needed any converter software although i did get a disc with the cable, think its just for the drivers though
bigjode
504
yeah, the drivers - when installing the drivers, it should say "usb ---> serial convertor".
Jamie123
123
I have installed the drivers, when i plugged my new usb lead in, it came up automatically with the setup. But on vag com when i check the ports it come up COM3 is ok when there is nothing plugged in. is this right?
R953 VSE
i got my cable off ebay and if it wasn't plugged into the car it would say "port status ok, interface not found" or something like that. i tried plugging it into the car and when i did the LED on the cable lit up (not sure if they all have this?) and it worked fine then. Can't remeber if the ignition was on or off.
Jamie123
123
Thats exactly what mine is doing and the led is also coming on when i plug it into the car but it doesnt seem to be communicating to the laptop. What com port did you select mate?
R953 VSE
can't remember which port i used but i remember going into device manager, in the ports section, and opening the properties of the usb lead bit in there. went into the port settings tab and into advanced settings and tried changing the com port number in there to either 1,2,3 or 4. it wasn't my laptop i used and it was a few months ago so i can't be sure if it was this that got it working for me.
ibiza_95
1.8T MK2 Conversion
i use com port 4 on mine. It will only work if plugged into the car and the ignition is on (engine running is fine) com port 3 looked promising but wasnt actually the right port.
Just test all the ports, see if there is one that looks significantly more promising than the other. Then you have to run one of the scans (autoscan probably) then it should run fine.
If i doesnt work like that then id do whats said above, didnt have to do it on ine tho :D
Jamie123
123
The thing is though on COM3 it says port status ok, interface not found. This is when nothing is plugged in.
Ive tried to get to the device manager but i dont know how the hell you get to it on windows xp
R953 VSE
so what about when it is all connected and your ignition is on, what does it say then?
i have no idea about what i explained earlier, its just one thing i remember trying when i couldn't get mine working.
if you right click on 'my computer', properties, hardware, you will get to the device manager from there if you need to.
Jamie123
123
OK, finally a bit of progress. i found out how to get to the device manager and check the ports and the cable wasnt installed.
The new cable is now installed but it is still doing the same with the ports on vag com, saying that COM3 is ok and the rest are not even when nothing is plugged in.
Jamie123
123
Finally got it to work which is great, im very happy thanks for all the help guys.
It came up with a code when i went to the engine option which is why the warning light was staying on, it said something about glow plug circuit in cylinder 1 and 4. i cleared it and the light went off
Jamie123
123
Saturday, 20 January 2007, 18:45:58
VAG-COM Version: Release 409.1-US
Control Module Part Number: 038 906 019 KG
Component and/or Version: 1,9l R4 EDC 0000SG 5342
Software Coding: 00102
Work Shop Code: WSC 06402
Additional Info: VSSZZZ1MZ5R082606 SEZ7Z0E3068174
4 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10) Electrical Fault
P0671 - 35-10 - - - Intermittent
17056 - Shareware Version. To Decode all DTCs
P0672 - 35-10 - Please Register/Activate - Intermittent
17057 - Shareware Version. To Decode all DTCs
P0673 - 35-10 - Please Register/Activate - Intermittent
17058 - Cylinder 4 Glow Plug Circuit (Q13) Electrical Fault
P0674 - 35-10 - - - Intermittent
This is the information from vag-com. I have cleared this so the light has went off but what should i do now about these, will the light come back on?
