DV return pipe swollen?
Legojon
I only wanted a remap
5,316
2,748
Um, sorry for the poor quality of pic. I take it the dv return pipe isn't supposed to look like this?
It kind of feels like its got a worm wrapped around it.
Leeoncupra
764
191
Halesowen
Mine looked similar i replaced it with a forge one was around 45 quid posted
leon cupra rtech stage 2, 3inch turbo back exhaust , forge twintake , r8 coil packs - 323bhp 333ft lb
Jfox
395
I swapped mine for a yellow one (forge dont do yellow sadly).
buy you can get them in blue easy enough.
I have a small bit of wear on mine but it looks pretty good.
Cheap enough to replace and saves any drama
O2gtCHBW3xJzRUxqKgFM_MBeRC_FMBUrQpf8j8cQ_VjU3U5e349NUBIm68FiRCOs0jvYfryfNgpZCF4JTceFCiipV9RTXe3ALYOCMsuZ3c2Lpcekkk4eog_Zdi68KrCKXD-33ikf08kRcMxWgpFGEcdT7tbevA96NJdYBxJOPkVF6g5u33ucV7JSPL8w-zBTUgE3--C33EZ3ZTeq0ziKkpcnxVl8oQQ-hpdR07m3ehL2kxI2zuPjnH7Fz2HTsLJgnqUmH_wclqi1IBgSUQgVE0A80qqzev4oefhqxeMmM78jXjRMP4JJeqh5u5SS07w4tgWXrjLHaJrY6Qz1NDXaQYWVOlVB81chq__rKnmHrKKtxLU8znk6N2iJK4hrp4i6KUuIw-qfPV0wRrE56cC6dKgCdgoSnlyJEyeEbSaRQZOTBPiVKMf7271mz_gbXVng2iHNxcE95u9bKsGbuFNAfMcxLc3yz9MfCCweQ_eSG2VL15X6XtQ60xBrN6PFlD5oJ-mLVLLTXkpfVTypIOYGXCeYjpuOyGPKfCBQscc0H1ITAWeQ8Azham7aTDyU-RTWt7UySQ_A63JkvRsAO5ybJeSPrAThZWbIZKyLNsFigTjfMqc-z7jYLTzH=w1263-h947-no
Excuse the lack of engine cover. I was changing my coil packs and take photo's of everything i do on the car :)
Legojon
5,316
2,748
Cheers, just ordered the Forge replacement pipe in blue. Trouble is, now I want to do all the other pipes in blue as well :)
Leeoncupra
764
191
Halesowen
They do look a good touch
Legojon
5,316
2,748
Yeah, looks smart. If the weather holds out I'll hopefully fit it tonight. I assume the pipes under a lot of pressure, how tight did you do up the jubilee clips?
Legojon
5,316
2,748
Hmmm... that was tricky... I tried to route it like yours, but because the Revo intake is in a different place I couldn't.
In the end, I literally had to stretch it into place. Also, it sticks up. I hope every time I shut the bonnet it doesn't put pressure on the sticky out bit on the intake.
Oh... and its near impossible to get to the dipstick now. Have i done something wrong?
Leeoncupra
764
191
Halesowen
Funny you say that , mine seemed to be ok when fitting my revo intake today. Maybe the angle on your intakr 90 degree bens is slightly off causing it to pull
This is mine as of this morning
leon cupra rtech stage 2, 3inch turbo back , revo intake , r8 coil packs - 323bhp 333ft lb
Legojon
5,316
2,748
Hmm, looks that way. I did try and go round that pipe but it wasn't really working out for me unless I bent the grey pipe backwards which I didn't want to do.
Legojon
5,316
2,748
Thank you so much for the help. I couldn't just leave it like that. So I took it for a run to get it warm. The pipe was kind of rolled up for posting and hard to work with initially. With the pipe warm and pliable I easily managed to get it in the same place as yours!
Um, one last thing. The jubilee clip near the dv. I assume I'm supposed to go to the right of the bulge in the metal flange? I did it finger tight. But it seems to highlight the metal bulge.
Leeoncupra
764
191
Halesowen
Yeah thats correct , should be fine mate aslong as its not allowing air to escape/enter
Blue looks good though glad your happy...i suppose now like me you want to colour coordinate the rest of the pipes now lol
Legojon
5,316
2,748
Cheers. If I knew what I was doing I'd do the turbo / intercooler pipes in blue. Coolant in red. And vacuum in yellow. Then I'd know exactly what each pipe did. Lol.
