i'm gonna be messing around again with mine, some time soon. Not happy, but determined anyway :)
I can't see it being my dv, but gonna stick std one on for a blast and see what happens.
Has that Forge got all the 'o' rings in? If it has, sounds like you need a service kit.
The blue pipe on the scc car is an oil breather pipe, not a DV pipe.
yes it has , ok ill order one tmorrow how much?
where does the other end go? cos when i removed the intercooler pipes it was oily, it this venting back to the air intake a cause of this?
I think someone said they've used the washer bottle as a catch tank. Yes, it's the crank case breather and the recirculation I think.
would you say getting an oil cach tank is a good idea?
cheers pabs ill try that tonight
It's a "good" idea yes. But only really needed on the track, I would say. Not going to hurt anything, but a bit of a waste on a road car.
ordered a service kit from forge today, and the MAP sensor bracket, so im gonna get that made up into a piece of silicone pipe with a dv take off on it too
