Dump valve(Help)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Well when i got the cupra the lad said it has a Dump valve from a audi a3 225 anyway ive had a closer look and it looks like a normal bosch dv..
This is the vid of what is sounds like and tbh it sound chatter...So am i right in gettin a forge 007p as soon as possible?
http://uk.youtube.com/watch?v=rCvb0XVaWw0
And the pics..
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
i just spoke to the lad i bought it off and he said he got it off the 225 S3 and the spring inside has been changed...To let it open for longer and it runs and performs fine aswell but if its not ment to make that chatter on vag engine then il change it asap...
Would u recomend the split r valve or the 007p i also have a large pipercross open cone filter aswell
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
having the DV open for longer will slow it down mate!
fuk it off and get a forge. if you want a strange sound the yea get a split R
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
Depends on if you want a loud dv noise or not, most people find a open cone and 007 work just aswell and leave on what they have got.Can pick up a 007 for £50 now second hand look in the for sale section.
h17och
Sep 1, 2005
3,504
Dunstabubble
to test it.....
remove it,
push ya finger in the bottome hole and push the piston right up,
put ya finger over the smallest hole (top),
let go of the piston.
it 'should' stay up, untill you remove your other finger and it should spring back down
understand?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
I have a forge split R on my Cordoba 20VT. I was also hoping for the loud psssss sound just like the subaru, but unfortunately this was not the case. I have heard someone else describe it once as a public transportation bus opening its air pressured doors :cry: although I don't think it is that bad. It is just a soft psssh. Furthermore you have to set it to the right click (there is about 53 clicks) I believe for a regular 20VT you open it all the way and then bring it back about 16-19 clicks. If i am wrong please correct me because that would mean mine is off :whistle:
This does bring me to the next question (if that is allowed within someone elses question)
When I chip my cupra (soon) to +- 200 BHP will the psssh become louder? :confused:
And what other methods are there to increase this sound (and ofcourse the HP's? [B)])
thanks
