Dump valve as standard
weeksuk
Does a dump valve come as standard on the 1.8 20v turbo 180 cupra?
Bogwoppit
1,085
Lincs
Its not a dump valve really as dump valves make dump (whoosh) noises. The 1.8t comes with a Bosch recirculating valve which recirculates the air instead of dumping it.
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Otherwise known as a Diverter Valve. Depends who you speak to... but different ways of saying the same thing basically.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
flappin sound?? not sure wtf your on about mate? been smoking crack? :lol:
blow off valves make lots of noise, but your not supposed to run them on 1.8Ts
the forge split R combi valve is the closest thing you can fit
225
1,836
uk
havn't had this one for a while!!
If you want noise and a knackered engine buy an after market atmospheric DV, if you want some noise and a healthy engine buy a re-cirv after market DV (such as forge 007p) and an induction kit. :)
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
Exactly what I've just done...(see sig)
Used to have an HKS BOV on my GT4, but now a little older, and looking for a more stealthy approach have opted for the 007P & a Raid MaxFlow.
RobM
Sep 27, 2006
4,982
Southampton
which 1 gives you the flappin sound lol
If by flapping you mean wastegate chatter... then a broken turbo gives you that on a 1.8T engine.
If you mean the whooshing noise, either a recirculating valve and an induction kit... or Forges new Split-R valve.
tomodono
i bought my cupra with a forge dump valve,(not atmospheric) if i remove the wastegate pipe will that give me some sort of (wooooshing) sound lol
dmmsta
Feb 10, 2007
787
Maidstone - Kent
From what i've read the 1.8T engines fault-code with they don't have a re-circ DV, so yes you'd get wooshing, and also Check-Engine-Light too....
Someone with either confirm or correct me i'm sure.
RedR
13
GLOS
I have a 51 plate leon cupra and run a Forge 007 with a green panel filter. Get
quite a loud whoosh sound. Car goes so much better than with the standard
Bosch D.V and filter. A lot less "Laggy" than before.Money well spent :p
tompotts
Touch me in the morning!
Mar 17, 2007
269
Guys Im looking at uprating the recirc valve, i was thinking of forge.
Can someone confirm whether or not the forge will make my car sound like a bus pulling into the stop, Ill be fitting it with a green panel filter too.
Cheers.
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
There is definitely a definite whoosh with ythe Forge 007p and Induction kit but its still quite suttle but I like it this way! Sounds better when you floor it and change up! or even just lift off! :D
RobM
Sep 27, 2006
4,982
Southampton
As above... the Forge 007P is a recirculating valve so you will only hear a minor noise when the air is dumped back into the air box. It is not particularly audible from the outside of the car unless you're really trying to hear it.
The Forge Split-R is a part-recirculating and part-atmospheric valve. It recirculates just enough to stop the ECU from having a fit, but dumps enough to give you the noise you want too. This valve can also be 100% recirculating if you decide you don't want the noise anymore.
