DRL gone yellow and dim
R4CK5
609
85
I'd be contacting dealer I think as the led lights are designed to last the life of the car I believe
gaffer1986
It's out of warranty now :( if only I had normal traditional headlights, this would be a simple fix, a new bulb.
I think that even if something is supposed to last the life of the car does not mean the dealer will take responsibility for it for the life of the car.
Big Col
626
89
North Ayrshire
i'd check the obvious first - the connections to the back of the headlight unit. I've never looked closely at LED headlights but I'm assuming they have some sort of multiconnector on the back of them.
You got VCDS? Does a scan show up anything?
The DRLs dim when you indicate or when you've got side lights on. Maybe a dodgy connection is confusing them?
Springrollz
109
London
Ive think I saw this car the other day in thamesmead on the flyover ! You're close ! Too bad it's not a cupra though
Springrollz
109
London
Hmm there's someone else stealing your idea of using a Fr Leon as a learners car. I'll find them and challenge them to a 30-100 for you . You're welcome
EFF11
138
38
I would contact Seat UK direct and challenge them on their claim that LED headlights will last the life of the car.
gaffer1986
That's a very good point.
Found the press release that states the lifetime thing:
http://www.seatpress.co.uk/release/882/
Thank you, having looked into it I'm suspicious it's the balast, can't see 3 out of 4 led strips failing together, but neither can I see two balasts partially failing either.
Sent from my GT-N5110 using Tapatalk
chrisRibiza
1,194
51
Take out an extended warranty....... wait a while then claim.
At £800 a headlight I wouldn't want to be paying the bill to replace them!
EFF11
138
38
Don't spend that kind of money before contacting Seat UK regardless of any warranty situation. That costs nothing.
R4CK5
609
85
Even if it states "designed to last the life of the car" if hardly call 3 years a lifetime!!!! I'd be getting on the phone first thing to seat uk for sure.
EFF11
138
38
Just found this in the Owners Handbook.
Full-LED headlights are designed to last the life of the car, and light bulbs cannot be replaced. In case of headlight failure go to an authorised workshop and have it replaced.
Clearly, the headlight is not fit for purpose if it cannot last as long as a conventional bulb. Talk to your local dealer. If you have no luck there go to Seat UK. I would expect a free replacement or, at least, a significant contribution to the cost of a replacement.
Go for it!
KoNG
504
106
London
you can replace just headlight daylight module part number 5F0941475 left 5F0941476 right 30£ used on ebay. New one around £80
